Just installed the latest version 4.14.0323. When I try up upload to my autoprom I get an error "FAILURE: Bin is larger than emulation RAM! Perhaps you meant to use bank 8?" I also get this if I try to download the bin from the autoprom. Any ideas what this might be? Everything worked fine until I upgraded.
Scott
Upload Error
Ok, I just uploaded a fix. Download and enjoy! Thanks for the report.sshook wrote:My bins are 64KB even the stock bin. I have a 94 Chevy truck with a 350. Using $0D with 16197427. This all worked OK untill I upgraded to the latest software.
Scott
Im getting the same problem, however Im playing with 256k Australian EEC-IV bins. How do I get around this as mine is substantially bigger than 64k. Ive set the jumpers on my ostrich as per Craig Moates instructions, Im running the FTDI drivers and I re-installed TunerPro this morning to the latest version as I couldnt get the older version I had installed to verify the bin properly. Keen to get this going as Ive been tuning via hex and chips and Ive had enough, I just want a good GUI to tune with, and Im sure TP is the answer.
Thanks in advance.
Thanks in advance.
The AutoProm's max size is 64KB. For an Ostrich or Ostrich 2, you need to use bank 8 (full 4Mbit), which is available from the emulation bank toolbar (view->toolbars->emulation bank).Jaysen wrote:Im getting the same problem, however Im playing with 256k Australian EEC-IV bins. How do I get around this as mine is substantially bigger than 64k. Ive set the jumpers on my ostrich as per Craig Moates instructions, Im running the FTDI drivers and I re-installed TunerPro this morning to the latest version as I couldnt get the older version I had installed to verify the bin properly. Keen to get this going as Ive been tuning via hex and chips and Ive had enough, I just want a good GUI to tune with, and Im sure TP is the answer.
Thanks in advance.
