16 bit item table does not update correctly during emulation
dfddfd2
Post by dfddfd2 »
Using TunerProRT 4.14.0381.00 emulating with Ostrich 2.0:
I created a 16 item table with 16 bit items (words) in the xdf. The table is already defined in the bin. I can change and update the first item in the table ok, but updates to other items change only the high order byte (bigendian) of the word in the Ostrich. Also, changes made to the last item have no affect at all in the Ostrich. The changes ARE applied correctly to the bin. When I upload the current bin, the changes are there and are correct. I tryed a single column, 16 row and also a 16 row, single column table definition with no difference. Please help! I need this functionality.
Edit: Another clue is if I change the first 3 items in the table, the first 2 update correctly and the third item is unchanged.
Dave
Thanks Dave. I'll make sure this is working in the next major release.
dfddfd2
Post by dfddfd2 »
Thanks Mark. Let me know if there is anything I can do to help.
Cheers,
Dave
