tps sensor
51 chevy
tps sensor
Post by 51 chevy »
hello i have 1227730 ecm with a rs323 cable interface.using rt aldl my tps reads 1.89v and if i mash on throttle it goes down to .80v.changed ecu eprom checked wires at tps volt meter shows .54 at computer harness shows .54 .if i unplug tps the rt aldl shows 25v ? so i down loaded aldl mon and with everything the same it shows .54v and goes up when i mash on throttle.
sounds like the aldl datastream definition you're using is incorrect. which are you using?
51 chevy
Post by 51 chevy »
im using the 127730eds file from the down loads.?if you know of a better one ill try it.
There should be one included when installing TunerPro RT. Does taht one work correctly? If not, check the TPS item in the definition and make sure its defined correctly.
51 chevy
Post by 51 chevy »
what should it be its divide(factor/x)+offset
factor 51.0
To display voltage, it should be set to multiply and the factor should be 0.019608.
