I know that you have to use the 0x040E BPC Vs desired EGR.
Dose anyone know the formula to use specific injector.
Like 50lb, 55lb 66lb,72lb and 75lb injector sizes? At least those are what I need anyway.
TIA
Dan Cheatham
7749 Ecm -$58 injector sizing ??
Makes sense. That'll teach me to keep my nose out of area's of which I have little understanding.
Hopefully someones else knows the answer to your question. If not, the thirdgen.org boards are a *great* place to get this answered.
Mark
Mark
Re: 7749 Ecm -$58 injector sizing ??
The book sez:Cheatham 2492 wrote:I know that you have to use the 0x040E BPC Vs desired EGR.
TIA
Dan Cheatham
const = 1461.5 * EGR FACTOR * (liters/cyl) / injector rate
Where injector rate is in GM/Sec.
That number will only get you a ballpark figure for BPC... there's *way*
more to tuning $58 for large injectors than that. You end up messing with
a lot of different tables.
You can get one to run with the above, but it's only the beginning.
Later,
Dig
