I have a new laptop with no comport but 3 usb and found a usb to rs-232 thats works with 8192 baud.I have tested 2 usb and 1 pcmcia thats not
working.
http://www.vscom.de/produkte/vscom_usb-com_mini.html
This workes with tunerpro,scannerpro and datamaster for me.
I have the mastach cable
http://www.mastach.com/
Laptop is a packard bell 1500mhz.
A usb to seriel cable thats works with aldl
It has been a while but I needed to use WINALDL to update my ECM using a new computer that has only USB Ports. I wish to pass my experience I had in picking a USB to Serial Adapter that will work with this great program. What I leaned there are two type of drivers used to support USB to Serial Converter. The most common is the Direct Access to a USB Device via a DLL Interface. This will not work for WinALDL and many other programs that were coded to use only a RS232 port. I found a USB driver called Virtual COM Port (VCP) that emulates a standard RS232 device. One Mfg that support the VCP is FtdiChip (www.ftdichip.com). A company that uses this Chip-Set in their USB to Serial Adapter Cable is EasySync Ltd (www.easysync-ltd.com). I hope others and happy tuning!
Byron T.
Byron T.
