Sil
Posted: Wed Oct 11, 2006 11:45 pm Post subject: little crawly things... |
bugs !!
#1
ok so i added everything, and i go to work on the dash next...
and i found that after i create a dash, in this case i created analog one that was 0, 0 50, 25
ok, showed up in the upper left corner...
then i go to right click to asign rpms to it and it crashed scannerpro
keeps crashing it when i select anything to asign to it
#2
when creating a new value, and it was created at the bottom of the list, and you go and delete it you get locked in, and cant click anything properly untill you close the editor
#3
colors some times dont stick on values only happened twice, cant reproduce consistantly, sorry
#4
graphical hangups when changing views in the dash, this can be fixed by simply resizing scannerpro horizontaly or verticly or w/e a lil smidge
#5
seperator dissapears sometimes after exit/open scanner pro when using special characters
#6
importing an ads file results in loss of value names when using special characters in the names in the .ads file
mmm guess thats all for now, great program just cant figure out the darn dash crash
keep up the good work mark, glad to be beta testing this software |
