Bitmasks
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    TunerPro User Forum Forum Index -> ScannerPro Beta Discussion
Sil
PostPosted: Wed Oct 11, 2006 5:01 pm    Post subject: Bitmasks Reply with quote
cant figure out how to add bitmasks
i dont understand, like in tunerpro rt aldl editor you put in the address
then put in the bit
in scannerpro there is operations?wtf
say i want to add the following, how would i go about doing it....
Code:
 59      FMDBYTE1     BIT STATUS WORD
            0      PARK/NEUTRAL                                1=OFF  0=ON
            1      3RD GEAR                                    1=ON   0=OFF
            2      4TH GEAR                                    1=ON   0=OFF
            3      P/S CRAMP    (0=CRAMP)                      1=OFF  0=ON
            4      READ BUT NOT USED
            5      V5 COOLING FAN DISCRETE (A/C PRESSURE SW)   1=OFF  0=ON       (1 = REQUESTED)
            6      DISCRETE CRUISE CONTROL                     1=OFF  0=ON
            7      AIR CONDITIONER REQUEST                     1=ON   0=OFF
Back to top
PostPosted: Wed Oct 11, 2006 6:37 pm    Post subject: Reply with quote
Bitwise AND
0x1 = bit 0
0x2 = bit 1
0x4 = bit 2
0x8 = bit 3
0x10 = bit 4
0x20 = bit 5
0x40 = bit 6
0x80 = bit 7
so, for 4th gear flag, set the offset to 58 (0-based), Bitwise AND, operand is 0x04, and result is 0x04. This is the same as saying "if the data at offset 58 is ANDed with 0x04 and the result is 0x04, then the flag is set, otherwise it's cleared".
More information on bitwise operations here:
http://en.wikipedia.org/wiki/Bitwise_operation
_________________
Back to top
Sil
PostPosted: Wed Oct 11, 2006 7:01 pm    Post subject: Reply with quote
alrighty, thanks for clarifing
was confused when i was looking at the 8d adx and seen values like 3c ect..
so when i compared that to the a100 aldl stuff it didnt match the address and i got confused lol
Back to top
Display posts from previous:
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    TunerPro User Forum Forum Index -> ScannerPro Beta Discussion All times are GMT - 9 Hours
Page 1 of 1
Jump to:
