"Error - One or more checksums could not be updated. &q
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Report A Bug
InfernalVortex
PostPosted: Sat Dec 30, 2017 2:06 pm    Post subject: "Error - One or more checksums could not be updated. &q Reply with quote
In TunerPro it continuously gives me this error on any and all bin saves. I can open up a virgin, untampered bin, and save it in a different folder making zero changes and it gives me this error.
It's a laptop with Windows 7 Home PRemium. 64 bit. Core i5, intel graphics or something I think.
The same xdf and bins from the same disc save perfectly fine on a different desktop computer, but I need it to work.
This is with 5.00.8853.00
I tried to use 5.00.9130 but it doesn't install at all.
This laptop works perfectly fine for all the other things I use it for. It's not especially old or damaged. Im at a loss, but it seems like a hardware issue but Im not sure what I can do to fix it.
Back to top
InfernalVortex
PostPosted: Sun Dec 31, 2017 7:31 am    Post subject: Reply with quote
It appears version 4 doesn't have this problem. Only version 5.
Back to top
Fierobsessed
PostPosted: Sat Jan 06, 2018 11:14 am    Post subject: Reply with quote
Looks like an issue I'm still having too.
http://forum.tunerpro.net/viewtopic.php?t=4012
Try just simply reloading the XDF then re-save the bin. If it doesn't give you trouble then yours is giving you the same problem I have. It has persisted from 5.00.8853 into 5.00.9107
_________________
88' Fiero GT 3.4 DOHC F40 6 speed GT3582R running on $8F.
Back to top
View user's profile Send private message Send e-mail
Fierobsessed
PostPosted: Thu Jan 11, 2018 3:18 pm    Post subject: Reply with quote
Found a workaround. It seems like if the Definition (XDF) is in the same folder as the tune (BIN) this issue shows up. Create a new folder and put the definition (XDF) in there and the issue goes away.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Report A Bug All times are GMT - 9 Hours
Page 1 of 1
Jump to:
