Data Acquisition for Lancia Lancia_v1.adx
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Other Car/Truck Makes
zioweb
PostPosted: Sat Sep 04, 2010 11:20 pm    Post subject: Data Acquisition for Lancia Lancia_v1.adx Reply with quote
Hi all,
I've downloaded from the tunerpro site the file Lancia_v1.adx and want to use it on a Coupè 2.0 16v turbo.
How can I interface the PC to the ECU for Data aquisition?
I need a particular ALD interface?
Thanks Smile
_________________
Power On The Road Equipped
...I always do by myself...
View user's profile Send private message MSN Messenger
hnracing
PostPosted: Sat Sep 11, 2010 7:51 am    Post subject: Reply with quote
Do a search on ebay for
"obd2 usb vag kkl" and
"Fiat Lancia Alfa RomeoOBD2 Diagnostic adapter "
BR
rob
PostPosted: Sun Sep 12, 2010 8:27 am    Post subject: Reply with quote
Currently this Adx expects only one Byte in Return! All the KKL Interfaces i've seen echo the sent data! So you will very likely get garbage.
Solution 1: Modify the KKL Adapter.
Solution 2: Modify the ADX and send it to Mark with a different name (Lancia_v1_KKL.adx for Example).
ROB
hnracing
PostPosted: Sun Sep 12, 2010 10:36 am    Post subject: Reply with quote
Just go
Acqusition ->Edit definition ->ADX Header Data
- check the box for "RS232 Echo"
Save
Done!
zioweb
PostPosted: Sun Sep 12, 2010 11:18 am    Post subject: Reply with quote
thank U very much for the explanation, this sounds very good to me because I have the kkl interface and the 3 pin adapter Smile
thank U very much!
Smile
_________________
maxim
PostPosted: Tue Apr 29, 2014 12:41 am    Post subject: Reply with quote
dear friend I know this topic very old.
I need some help about marelli P8 ecu.
I can not connect over tunerpro5 with Lancia_v1_1.adx to ecu.
4W6/P8 alfaromeo 155Q4 ecu (like lancia 16V)
-I have original lancia tester diagnostic, its work well
-Im registered tunerpro user and I have ostrich 2.0 emulator, its work well
-I have 409.1 KKL usb interface and 3 pin fiat cable,
its work well with startrek software on notebook from "nailed barnacle"
finally evey devices are working but Lancia_v1_1.adx NOT.
Im set it correct com port in configure menu com6
but tunerpro give me an error when I test.
"TEST FOR VALID INTERFACE USING SETTING" -> cable not found or not functioning.
midnight_man
PostPosted: Sat Jun 03, 2017 2:31 am    Post subject: Reply with quote
anybody tried this adx with elm327?
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Other Car/Truck Makes All times are GMT - 9 Hours
