import definition from ADS not working for V5
studboltgkw
Post by studboltgkw »
I have TurnerPro V5. When I go to the Acquisition's tab and select Import Definition -> from ADS. The "Select ADS" pop-up window appears in order to select the ADS file. Once the ADS file is selected . . . then window disappears and nothing happens.
I do not immediately get the "Select file for saving converted ADX" window.
studboltgkw
UPDATE: only after you close out of the TurnerPro V5 software does it prompt the user to save the converted ADS file to ADX.
