XDF for E36 euro M3 S50B30
Posted: Sat Jan 14, 2017 5:18 am
by Brian Shor
My circuit E36 M3 has a 3.0l euro M3 motor running on bosch 0261203075 (chip 1403157). I have been working on a xdf for this ecu but having issues with the address for WOT ignition. DOES ANYONE HAVE A XDF FOR THIS DME?
I took out the stock chips that made 256whp and install the AC schnitzer 320 chips and made 273 whp, but now I need to tune on 104 octane.
Re: XDF for E36 euro M3 S50B30
Posted: Thu Jan 19, 2017 5:31 pm
by mohamedramli
do you use the XDF from tunerpro download section? I am planning to tune this ecu soon, planning to use the xdf from the download
Posted: Sat Jan 21, 2017 10:25 am
by Brian Shor
The XDF in the download section is for a 081 bin, the OEM bin for my S50B30 uses a 078 bin so I can't use this xdf. When I get some time and sort the xdf I will give an update.
Posted: Wed Mar 08, 2017 11:35 am
by Brian Shor
I have gotten a few PMs regarding the xdf for the Euro S50B30 (92-95 Euro M3). I have done a xdf and have carried out road tuning adjustments but I have not gone to dyno yet to measure the actual output and fully confirm the xdf. Note my ecu is 075 dme with 078 software.
Posted: Fri Nov 24, 2017 12:58 pm
by kortex16v
Hi guys
I would like to know if it is possible to swap a harness wiring with the DME 413 for tunning my S50 euro.
The number of sensor is not the same, but if I put the sensor of the M50 can it work?
I started to develop the DME 075 by relying on your work on the 413/506.
Most people in Europe with m3 euro S50 switch to Vems or other but I'm sure the DME 075 has the same capacity for scale ecu turbocharging as the 413.
Nico
Posted: Sat Nov 25, 2017 5:41 am
by Hairyscreech
I think a lot of what has been posted on the M3.3.1 ECU should help with the B30 engines ECU.
It is only an M3.3 with an added vanos controller computer.
Best thing to do would be post up a stock BIN and when I get a chance I will see how it lines up with what we know about the other M3.x series ECUs.
Posted: Sat Nov 25, 2017 8:05 am
by kortex16v
Posted: Sat Nov 25, 2017 8:14 am
by kortex16v
thanks to your work on the 413 I managed to find a lot of things but I can not shift the axis for a config turbo.
when the engine load is too high (in 4 gear at 2500tr / min> WOT) the AFR is not good as if the ecu read only half of the map.
If I work in real time with ostrich, I get to trace in tunerpro but the slider is not the right engine speed.
Posted: Sun Nov 26, 2017 9:40 am
by Hairyscreech
A solid understanding of the axis is needed for this one, and probably a good look at how Motronic treats load.
Take a look at the axis info here:
https://web.archive.org/web/20111016024 ... map201.htm
And here:
https://web.archive.org/web/20111016023 ... map301.htm
With that is mind take a look at a thread a little down this forum on a turbo tune, I put a clunky axis calculator in there that will help understand how to rescale map axis.
http://tunerpro.net/forum/viewtopic.php?t=4440
Posted: Sun Dec 03, 2017 5:29 am
by kortex16v
I have extract My VNC controller .
it's hex format but the writing is not the same of Dme .
https://dropfile.to/jgoDwj8
Kortex
Posted: Sun Dec 03, 2017 10:55 am
by biela
Hello
Intake vanos map is at 2820 16x16
2800 is TPS or load.
2810 is rpm.
