OD dataloging problem
jgarner
Post by jgarner »
Trying to datalog my 91 s10 with 94 4.3 4l60 7427 swap. I'm using od_tpv5_v250.xdf and a217 $od tp5 v250.adx. When I connect koeo all data is good but as soon as I start the engine I get more data errors than good data and if I drive it eventually the data just stops. I have tried adding a pause to the adx but nothing I've tried has worked. Today I tried a218_od_trans2_v250.adx and it connected engine running with no errors. Also I have a scan tool that will connect and show live data just doesn't have the ability to record. Any help is greatly appreciated.
xnke
Post by xnke »
I am having this exact problem. It's only with Tunerpro, no other software seems to have an issue. This includes tunercats, Winflash, Scan94/95, and Freescan.
I'm working with a P66 V6 ADX/XDF, though, but the symptoms are the same.
If the engine is not running, but the key is on, connection data is fairly solid. If I try to connect while the engine is running, connection will fail. If I connect, then start the engine, the data rate drops from a solid 11-13hz to 2-3hz and the data errors start piling up very, very fast.
I can provide the BIN, ADX, XDF, and a datalog of the issue.
