WOT map
maxout
WOT map
Post by maxout »
If the car does not go in to the WOT map, what should I look at then? Tps? are there more then that?
Its a 325 NV 92 402 motronic 3.1
Guybrush
Post by Guybrush »
probably tps is the reason use a multimeter to check the voltage.also check if the throttle opens at maximum
