Where do i start???
maxout
Where do i start???
Post by maxout »
I have M3.1 BMW 325NV 92.
Turbo, deka630, maf bigger, e85 fuel, 1bar.
I have a perfect map but getting lean on full wot, even if i messing with my fuelpressure, the injector should manage the effect im at...
If i want to go from lambda 1(AFR 9,7) to lambda 0,8 how/where do i change...
what does the injektor constant do?
maxout
Post by maxout »
what is most beliveable that is wrong if the car is stoppes ignite after 5000rpm,,,
maf, tps or lambda sensor?
