Hi im new here i have a e36 with m50tu stroker 2.8l i use moates 2.0 on a 413 dme red label
i have download bin and xdf from the internet for a 413 and 506 dme and on each xdf file that i have the map for fuel wot retard in afr look strange
like this
rpm load
680 12.4
680 0
680 0
680 0
680 0
680 0
the hex adress is 0xD992 on the 506 and 0xD994 on the 413
someone know whats my problem ???
sorry fo my english im from canada and i speak french
thanks
413 506 dme
It sounds like the bin file does not match the xdf you are using. There is more than one bin for the 413 red label ecu. Each bin has the data at slightly different locations. So you need to make sure that the xdf matches the chip you are using. You can view the chip number through the xdf, there is a tab for it. The xdf posted is for the #623 chip. PM me your email address and I can send you a updated 413 xdf and matching stock bin so you have the correct files to start with.
