Moto Morini Granpasso 1200
Marcox81
Post by Marcox81 »
Ciao!
Really interesting software.
I have a Motomorini Granpasso 1200, and this evening will try to obtain the bin file from my remapped ecu.
So can I send it to you for the xdf build?
Greetings from Italy
916 RS
Post by 916 RS »
Yes you can do.
:wink:
Marcox81
Post by Marcox81 »
Hi, I've tried to use the guzziDiag ecu reader, but it can't work.
Can I use a plugin of yours?
My ECU is IAW5AM OBD2
916 RS
Post by 916 RS »
Have never tested Guzzi Reader.
But it`s the only freeware at the moment to
read as bin file.
Have no plug in.
Marcox81
Post by Marcox81 »
Thank you, I will try again :(
I'm a member of an Official Granpasso Forum, and we are all interested in your software.
pauldaytona
Post by pauldaytona »
Marco has downloaded a map from his Morini with Guzzidag, and made his own xdf for it.
Marcox81
Post by Marcox81 »
Hi do you have the adx for the IAW Magneti Marelli?
Just download the OBDII plug-in?
SamuTnT
Post by SamuTnT »
Hi guys, i'm a Granpasso owner too, i've downloaded the .bin file from my bike's ECU, now i need the .xdf to correctly open the .bin in TunerPRO, should i send you the .bin file or the one generated for Marcox81 can be used by any Granpasso owner?
In that case is it possible to have that .xdf?
Another question, i'm not really sure of what the .adx file is needed for....what i've undestand is that it's needed to create the .xdf file , but in the case that the .xdf file is alreaady done the .adx is not needed, right?
Thanks for your work guys!
Bye!
