G60 Digifant XDF File 1267356189 16V Turbo
Hi I have built a golf 16V Turbo with Digifant I ECU. Unfortunately, I find I no matching XDF Filde or OLS. The main maps I already know. Mainly I'm missing the Revlimiter and the cold start device gasoline correction. I hope someone can help many thanks
Hi guys,
Can someone help me to program a speed limiter over ignition interruption?
(Winols) and also the normal fields, tuning is also no problem only I know not with source code read / write from ...
The main rev limiter are over fuel cut i see on my lambda-tool
It is the g60 3ignition map
Apologize in advance, work with a translator, come from germany ...
For answer I would be really grateful.
Greetings Benny
Greetings Benny
