hlr
Post
by hlr »
Hi! Is there any way to set revlimit more than 7000rpm? I put more and engine was stopped around 6200.
aboutton
Post
by aboutton »
what DME you are working with ?
HyperBoost Tuning
Tony Ouneissy
Lebanon
hlr
Post
by hlr »
I work with 0 261 200 380 and 0 261 200 173
aboutton
Post
by aboutton »
all motronic 1.3 ECUs can go up to 10200 rpm,
are you sure you are using the correct xdf for your file ?
HyperBoost Tuning
Tony Ouneissy
Lebanon
hlr
Post
by hlr »
Is the XDF from tunerPro.net
I made a new eprom with a little less than 7000rpm, but untill now couldn`t check it.
hlr
Post
by hlr »
Think i got it. There should be 6 more positions for revlimit and limit buffer.
tunesss
Post
by tunesss »
a
tunesss on Mon Feb 18, 2019 7:10 am, edited 1 time in total.
hlr
Post
by hlr »
Revlimiters:
1: 42DD
2: 4309
3: 4335
4: 4361
5: 43D8
6: 43B9
7: 43E5
8: 4411
Buffers:
1: 42DE
2: 430A
3: 4336
4: 4362
5: 438E
6: 43BA
7: 43E6
8: 4412
I don`t know which of these ecu uses or not. I just set them all same.
