Hi I am new to tuner pro so be gentle. I am trying to figure out maps used to standalone.We have a 325 with cam and it is going lean 5500 and above looking to enlarge injectors with timing but there is multiple maps for idle mid throttle and 3 wot maps which ones do I go for first.
MANY thanks mARC
bmw 325 e30
if you are using the ostrich emulator with tunerpro RT you can trace the maps to find out which ones the ECU uses and just tune those.
if you have a motronic 1.3 ECU then i have an extremely good XDF file for the M20B25 depending on what XDF you are using at present. this is my XDF if your not already using it: http://www.tunerpro.net/download/bindef ... _sw705.xdf
you may need to switch to a 1267355705 bin file if the one your using is not compatible with the XDF. the 705 file is the most common file out there for the B25 so theres a little more support/knowledge out there if your using that file. its what i run my own 325i on.
EthosMotorsports
