given this data can anyone derive the formula relating v to PSI i calculated the correlation which is 0.998930946 so there is very close relationship between these numbers
Using the above formula will get the following:
0.5v=0psi
1.2v=12.2psi
1.65v=20.1psi
2.2v=29.7psi
2.75v=39.3psi
3.45v=51.6psi
3.9v=59.5psi
4.6v=71.7psi
should you come across non-linear or otherwise difficult conversions to calculate an equation for, you can always punch them into a lookup table and have tunerpro interpolate the values.
robertisaar wrote:should you come across non-linear or otherwise difficult conversions to calculate an equation for, you can always punch them into a lookup table and have tunerpro interpolate the values.
