unless your application supports individual injector shutoff and you know how to force it to happen, this isn't something you'll be able to directly find out using tunerpro.
If this relates to your MEFI equipped boat engine, there is not much related to the injectors that you can check. There are some error codes that will indicate a short or open in the injector circuits.
