How to change xdf
gtomlarson
How to change xdf
Post by gtomlarson »
Can you change the 8d xdf temp tables to
show F degrees and not C degrees
Post by Six_Shooter »
Yes, it requires modifying the XDF itself and the calculation. Do a search on here, to find instructions of how to do it.
gtomlarson
I tried but can't find anything
gtomlarson
I know how to edit the xdf, I need to know
what constant to put in
EagleMark
Post by EagleMark »
There may be a simpler fix? I just looked at a couple $8D xdf and one is much larger and has a temp conversion table built into every setting that has to do with temp so you can just look at parameter comments when making the change. Also some other $8D stuff here:
http://www.gearhead-efi.com/Fuel-Inject ... rmation-8D
gtomlarson
I don't know what you mean by parameter comments,
can't find it anyware. Sorry
EagleMark
Post by EagleMark »
If there is a comment in the paremeter in XDF and you hover over it it will say what's there. Or click View, Paremeter comments or click the Paremeter comment button.
gtomlarson
EagleMark wrote:If there is a comment in the paremeter in XDF and you hover over it it will say what's there. Or click View, Paremeter comments or click the Paremeter comment button.
Sorry. still don't get it, this is what i'am trying to change
Fan 1 Enable Temp.
gtomlarson
I think I got it this is the expression they have
0.750000 * X + -40.000000 what would I replace it with
dfddfd2
Post by dfddfd2 »
gtomlarson wrote:I think I got it this is the expression they have
((0.750000 * X + -40.000000)*9/5) + 32
gtomlarson
Thanks I will try it and see what happens
EagleMark
Post by EagleMark »
If you click on the Fan enable temp and open the box, then go to button on top row that says View, then down to Paremeter comments a box opens with paremeter comments and has the C to F conversion in it. In the $8D Mod xdf someone made.
I guess you could change the conversion to come out in F but the entire bin is done in C. Using a conversion calculater would be safer...
gtomlarson
thanks guys works fine
gtomlarson
What would the conversion factor be for a table that has
rows to change them to F degrees
you want to change the labeling of the table to convert to/from *F?
http://www.wbuf.noaa.gov/tempfc.htm
that's the easy method.
gtomlarson
I'm after the conversion factor so I can change the XDF so all
my changes wii be in F degrees the factor it has is 1.000000 * X + 0.000000 what would I change to so it would come out in F
0*C = 32*F
10*C = 50*F
for every 10*C change, there is a change of 18*F
so instead of 1.0 * X, it will be 1.8 * X.
and to deal with the offset, change it to + 32
so X * 1.8 + 32 = *F, if starting with a value that was originally X * 1 = *C.
