monitor screen colour selection
The1
Post by The1 »
It would be very handy if you could select the colour for each item in the monitor screen itself rather than having to go back in and edit it.
I'm not sure I understand the request - are you asking to be able to change a series color without having to edit the ADX? If so, that's likely not something I'll change, as I don't anticipate that to be a common operation (unless there's more requests for such a feature).
The1
Post by The1 »
hi Mangus,
im refering to the Monitors Window, simply say clicking on the index for the item on either left or right edges to change the line colour can be random section, as i often change what's displayed on the monitor screen and am having to go back in and edit the adx to change the lines colour, perhaps even just something to check that the colour is not currently in use before assigning the line colour when changing items displayed on the monitor screen.
Hope this explains it better.
