Please Help XDF file for VR6 Transmission Control Unit
Haidar
Post by Haidar »
Hi there,
Is there any way to get the XDF file for the VR6'S Automatic Transmission Control Unit, where I can change the Shifting points, gear ratios ..etc parameters.
#096927731CH 1993 VW
or
#096927731BH 1993 VW
This module fit many cars 4 and 6 cylinders with transmission 096 and it is almost the the same only shifting points and gear ratio are different.
If it is not possible please users advice on a way to understand similar units.
revlimit
Post by revlimit »
Yes, if it has an Eprom in there, then you can tune it and make XDF files if you got information
