More COM ports to data aqusition
m0n5t3r
PostPosted: Tue Nov 08, 2011 11:28 am    Post subject: More COM ports to data aqusition Reply with quote
Hi
What do you think about possiblity to connect more than one interface to data aquisition. For example: One com is connected to ECU using narrow band o2 sensor and second is connected to Innovate LC-1 to proper and fast reading of AFR. That should let to read accurate reading without any change in wiring ( only connect power to LC-1). Another example will be ECU using narrow band lambda and using ASIC chip to decode signals - it can't be reprogrammed to use wide band (only modification in ECU diagram could help).
Back to top
PostPosted: Tue Nov 08, 2011 5:08 pm    Post subject: Reply with quote
I think this can be done through the use of a plug in. I know some people were working on being able to get Innovate products to be able to be added to the datastream by the use of a plug in at one point, not sure how far that got though.
Back to top
PhilStubbs
PostPosted: Thu Nov 10, 2011 9:00 am    Post subject: Reply with quote
Innovate provides everything needed to make a plug in on their website for free. I would have already done it, but that's over my head.
Back to top
desmo01
PostPosted: Sat Feb 18, 2012 1:15 pm    Post subject: Reply with quote
This would be super useful. I need to be able to use 1 datastream for ECU another for TechEdge WBO2. Both datastreams are already defined. If there were any way to add another COM input that would be awesome...
Back to top
Lucho
PostPosted: Wed Apr 13, 2016 12:17 am    Post subject: Reply with quote
I'm fully agree Wink
Log several (at least 2) comm ports at the same time would be very useful.
Back to top
Acki
PostPosted: Fri Feb 16, 2018 3:45 am    Post subject: Reply with quote
It would be enough when it would be possible to load 2 PlugIns at the same time - for each PlugIn a own ADX file and at the "first slot" you can but everything into Monitor or whatever or same Monitor/Dash for all.
Only datastream related stuff is PlugIn related.
2 ports at one Plugin is possibl´┐Że (OSE Plugin for exmaple) but this is too special.
I'm realistic, I don't expect a fast solution cause the last big changes are done years ago but I don't want to blame for the work which was already done.
Would be awesome when TunerPro would bring this feature Smile
/edit:
After thinking about the story I found the software "Serial Port Splitter" which seems to can merge com ports to one, I will try to "hang" the needed signal to the other - then it should work as before Smile
Back to top
cbernhardt
PostPosted: Sat Feb 17, 2018 4:17 am    Post subject: Reply with quote
I realize that this is an old post, but does anyone have a link to the plugin information on the Innovate site?
Back to top
Acki
PostPosted: Sat Feb 17, 2018 2:49 pm    Post subject: Reply with quote
Plugin for what? LC1? Other Innovate stuff?
Back to top
cbernhardt
PostPosted: Sun Feb 18, 2018 4:02 am    Post subject: Reply with quote
Innovate LM1.
Back to top
Acki
PostPosted: Mon Feb 19, 2018 10:54 am    Post subject: Reply with quote
Open Realterm and listen the transfer Smile
LC1 sends out B2 82 43 13 as header/footer and the lambda value in between.
Can't be more complicated with other Innovate stuff.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
