Data Monitor Display Bitmasks on/off
The1
Post by The1 »
Efilive V4 had this feature, when a bitmask turned on or off it displayed a indicator in the monitor graph, this is enabled via the usual right click in the monitor window to select what you want.
The1
Post by The1 »
the main reason i ask is because some vehicles dont have shift time as a value to graph, they only have a bitmask for solenoid on/off
cbernhardt
bitmask display
Post by cbernhardt »
Not sure about displaying bitmasks in the newer versions of Tunerpro, but I am using ver. 5.0574 of Scannerpro and all you have to do is create "Status" type gauge on the dashboard and then crate a "Bitmask" value to assign to the gauge. Of course you will have to know the packet offset of the value you want to display and the proper bitmask to use.
Charles
