I have a 94 GMC Sonoma with the 4.3 VIN W CMFI motor. I have been playing with trying to get TunerPro RT V5 to read live data but have not had much luck. I started with V4 and used the A178 definition file, but i could never get the data stream to start, I switched to V5, imported the definition which took it from a ADS to a ADX. I was then getting live data but it was all junk, only half the sensors were reading and the ones that were did not make sense. Any one have any ideas where i'm going wrong, or have another definition file i could try?
4.3 V6 VIN W help
Did you ever try any other programs or scanners that you had any success with? I need to see what is happening with the sensors to try and solve a problem. My engine misses at idle but only when it hits 195. Up till that point it's as smooth as glass. I suspect when it goes into closed loop and is reading all the sensors it starts missing. I have changed almost evey part you can think of including a new CPI spider but can't solve it.
