thank you, But... ?
thank you, But... ?
Thank you Very much for the ADS defenition file for my trck, But, I have some glitch. I don't know If it's supposed to be like that.
When I use TP, The reading are... Glitching. every 2 or 3 seconds, The data are like if there was no reading for alf of a second and Back to Normal.
I could post my XDL file, So, somewone could tell me if it's a normal reading...
I will have to ask something interesting. Is there a way to read the Check engine code with the TP RT?? I tought my problem was the Ox Sensor, But, Apparently the data I have are the normal operation of the sensor, So, Now, I need to read the code... I don't know anything about the rest of the values I have there....
Ok ,Heeee, What if... What if I don't have a Flags tab? I don't know If I am missing something, But, I seem to be unable to find a Flag tab... But, I am searching for this in replay mode... Do I need to be in Reading mode to see it?
If so, Where is it? So I will be able to find it Fast next time I plug the laptop in the truck... Thank you very much for your patience...
http://i.imgur.com/OJbsk.png
at the top, near the center, press the "F", then you'll have access to the flags tab.
you should be able to use it in both replay and live data modes.
Ok... Then, In this Tab, I have no information at all About the Error code... I have raw values that I barely understand... But, I have nothing like a Error code or anything that could be close to that...
What I will do, Is I will unstall the V5 And Try to see if the V4 is better to read the error data...
Will take 5 minuts to do so anyway...
Thank you very much again for your patience. I just realized how it worked! The come back to the last version opened my eyes! the program now regroup the Flag and the Data in the same tab!
Thenk you, You made me realize that the probleme was a valve that will cost me 400$ OR, I could buy a chip, Copy the prom on it, and disable the Reading of this EGR valve... Dunno how much this could cost me, And I don't know how to do any of this, but, I am sure I will find all this out very soon!
Again, Thank you!
Again, Thank you!
