Here's another Newbie needing assistance
I'm trying to figure this out myself but I am getting nowere.
I am having trouble connecting to the ALDL. The ALDL cable connects to the Computer through the eithernet port. Is there a setting on my computer or in the program that I have to change?
I have a 1990 Vette with a 1227730 ECM (5.7 6sp Man.)The Memcal says ARFP
I have loaded arfp8D.bin. Imported Super_8dm2.ecu into the dxf. and A115.adx.
I went into Tools \ Preferences and tried switching the plug-in Configuration but that did not work.
Please help, Thank you
Pat
Trying to scan but ALDL won't connect
Well first lesson learned for the newbie. I couldn't even make it through buying the equipment without messing up I thought I had it figured out. I spent almost two weeks looking at the moates sight before buying the equipment. But I guess I need a ALDL to USB converter. Oh well I hope the converter gets here before next weekend.
I have a lot to learn but we were all newbies at one time right.
I'm sure I will have more complicated newbie questions to come as I work with this software and pick up experience.
Hi Guys I would really apreciate some guidance here
I have a 1990 Vette with a 1227730 ECM (5.7 6sp Man.) SD, The Memcal has ARFP on it
Using: Tunerpro RT v.5, Ostrich II, Burn 2, ALDU1
I got the ALDU1 last night and tried to scan today but DA would flash blue:connected then red:error. Any idea what is going on? Or a forum and post I can look for
I have loaded arfp8D_MS.bin. | 8D.xdf | A115.adx.
I went into Tools \ Preferences and tried switching the com ports but that did not work.
Cable not found or not functioning (tested at 8192 baud)
I tried searching but have not came up with a helpful post. If you can guide me to a post that would be great
I need a prom tuning for the complete IDIOT post.
- Six_Shooter
When performing the cable test, make sure that it is NOT plugged into the ALDL connector under the dash. Many times if I have to perform that test while in the vehicle, I simply unplug the RJ45 looking connector that leads to the ALDL connector, while performing the test.
You may need to add some delay to the request response, There are a few posts on it, I don't recall the details off hand, to be able to post what needs to be done right now. I beleive either Saar or JP86SS have made posts about how to o this, or maybe both.
