Adding Value MAP Inches of Mercury
Trying to add a value in a definition for MAP Inches of Mercury (just as a reference since that is how I was taught) once done I will add it next to MAP KPA. But I need the information like packet offset, range and conversion information?
Just duplicate everything in the definition for MAP KPA and multiply the conversion and ranges by 0.2953.
For example, I have MAP kPa defined as:
title="MAP kPa"
id="MAPKPA"
units="MAP kPa"
packetoffset=0x3D
sizeinbits=16
range low="0.000000"
rangehigh="297.000000"
conversion="((x/200)*61.7284)+1.105"
I also have the same value defined in PSIg:
title="Boost (psig)"
id="BOOSTPSIG"
units="Boost(psig)"
packetoffset=0x3D
sizeinbits=16
range low="-14.500000"
rangehigh="28.400000"
conversion="((((x/200)*61.7284)+1.105)*0.145)-14.7"
Cheers,
Dave
title="MAP kPa"
id="MAPKPA"
units="MAP kPa"
packetoffset=0x3D
sizeinbits=16
id="BOOSTPSIG"
units="Boost(psig)"
packetoffset=0x3D
sizeinbits=16
Cheers,
Dave
Thank you, I will give that a try. it would speed up my process of diagnosing as I am so used to vacuum being in inches of mercury. I guess that went south when everything went metric?
That's one of the great things about TunerProRT. You can define any unit conversion factor you want. Another really powerful aspect is the ability to combine multiple logged values into calculated values.
For example, I have injector pulse width and RPM combined to calculate duty cycle:
title="Injector Duty %"
units="Duty %"
conversion="x*0.01*y/1200"
"x"="native" (injector pulse width in 10usec units*0.01=msecs)
"y"=link to RPM
Cheers,
Dave
units="Duty %"
"y"=link to RPM
Cheers,
Dave
Sweet!
My mind is churning but I am going to have to catch up my knowledge for things like "conversion="x*0.01*y/1200" "
