I have a 93 K1500 Chevy truck with the 16168625 ECU and BBLC bin. My setup is a new crate 350 with the obsolete Weiand supercharger kit. The kit utilizes an adapter EPROM so I'm assuming I need to do something extra in order to read data via Tuner Pro? I have the Moates extreme ALDL usb connector, just trying to figure out what else needs to be done in order to read sensor data.
16168625 ECU
Hmmmm, well I have these already, thanks for the link. My question was, will I be able to see data with that Holley chip attached to the adapter? I'm asking becuase I am not sure how the other chip is working in conjunction with the factory one.
Thought someone mentioned I wouldn't be able to read data after market chip, unless the ECU only looks at Holley chip with certain criteria. So I am just double checking.
