Copy XDF Parameters
yoda69
PostPosted: Thu Apr 15, 2010 9:33 pm    Post subject: Copy XDF Parameters Reply with quote
I'm spending a fair bit of time trying to update various Australian XDF's that have data offset within the different Variants of the XDF. Would be nice to be able to copy a parameter from one xdf to another, ie open new instance of TunerPro so 2 are running, add new XDF Table for example to one xdf, copy and paste into the other instance of TunerPro, update the address offset and done.
At the moment I'm having to create the table in multiple versions, and enter all the data again with the only difference being the data location.
Have tried editing the xdf by hand, but this isn't ideal either, as one small error can make it junk.
Keep up the good work,
yoda69
Back to top
PostPosted: Fri Apr 16, 2010 3:33 pm    Post subject: Reply with quote
You can copy entire XDF parameters via the right-click (context) menu in the item tree. Is that insufficient?
You can also open two instances of TunerPro.. You cannot, however, copy between the two instances.
_________________
Back to top
yoda69
PostPosted: Fri Apr 16, 2010 4:02 pm    Post subject: Reply with quote
It's the copying between the 2 instances I'm after, as this is the repetive and time consuming bit, especially if I have to add the same detail to a number of xdf's.
The rest is OK.
Greg
Back to top
PostPosted: Fri Apr 16, 2010 4:11 pm    Post subject: Reply with quote
Noted. Thanks!
_________________
Back to top
yoda69
PostPosted: Sun May 16, 2010 2:40 am    Post subject: Reply with quote
Thanks Mangus, works a charm.
Would there be any possibility of being able to select multiple xdf items and copy in 1 go. Was just copying some DTC flags between xdf's and had to go back an forward about 30 times.
Having said that, it's still way quicker than what I was doing in the past. Very Happy
yoda69
Back to top
PostPosted: Sun May 16, 2010 4:28 am    Post subject: Reply with quote
I haven't tried this, since I just installed the latest version yesterday, but have you tried holding the shift button and then the arrow button up and down?
Or "Ctrl" to select multiple items?
Back to top
yoda69
PostPosted: Sun May 16, 2010 4:37 am    Post subject: Reply with quote
Yes.
Will only allow selection of 1 parameter at a time.
Back to top
PostPosted: Sun May 16, 2010 4:57 am    Post subject: Reply with quote
Figured you would have. lol
Back to top
PostPosted: Sun May 16, 2010 7:22 am    Post subject: Reply with quote
Single selection only.
_________________
Back to top
dfddfd2
PostPosted: Fri Oct 22, 2010 4:22 pm    Post subject: Reply with quote
This is a great feature I use frequently.
Dave
_________________
Back to top
View user's profile Send private message AIM Address
prj
PostPosted: Tue Feb 22, 2011 11:38 am    Post subject: Reply with quote
Am I missing something or how do you open multiple instances?
When launching the second one, it always says that TunerPro RT is already running.
However, it is possible to launch two instances... patch the check:
Search for:
1C 00 75 44 6A 30
Replace with:
1C 00 EB 44 6A 30
And then you can open as many instances as you like. Also copying works between instances.
Mangus, could you make a checkbox option for this?
Back to top
dfddfd2
PostPosted: Tue Feb 22, 2011 11:58 am    Post subject: Reply with quote
Search for:
1C 00 75 44 6A 30
Replace with:
1C 00 EB 44 6A 30
You can pass -multiinstance as a command line parameter.
Dave
_________________
Back to top
prj
PostPosted: Tue Feb 22, 2011 1:06 pm    Post subject: Reply with quote
Dave
Doh.
It took me less time to find the place to patch in IDA than to find the parameter.
Epic fail on my part.
Thank you.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
