Hex Editor Views
Turbosport
Hex Editor Views
Post by Turbosport »
Marcus, can we add in a second view in the hex editor so you can flip between assci and a vertical block which height corresponds to the location value, this will make finding small maps very easy, we would need to switch the blocks between 8 and 16 bit also.
Keep up the good work my friend.
Clint
Who is Marcus? =)
ASCII values are displayed in the hex editor. Are you saying that you want a plain text viewer/editor as part of the hex editor?
Or are you describing the hex editor "value bars" that are present in another tuning software package?
-Mark
Turbosport
Sorry Magnus :oops:
I meant on the right hand side having the ability to switch to a view which can show the relative values of the data so if one was hex FF the bar would be 100% if the next one was 00 no bar would show.
Also the ability to copy the cursor location so once you found a table you can select and paste it into a new xdf item.
