I have finally got my APU1 and LC-1 working correctly. Can someone please point me toward what fields or tables will help me adjust my a/f ratio?
R.S.
Air Fuel Ratio ?
depending on the exact XDF you're using, you'll see these tables, in some wording or another. these are the ones you will use the most anyway, there may be another table or two and a few constants related to it as well.
Main Fuel Table Off Idle
Main Fuel Table Near Idle
WOT AFR vs RPM
Open Loop AFR vs Coolant Temp vs Vacuum
now, you'll need to get the main fuel tables correct, then you can mess with the other things, since they are based off of the main tables. if they're wrong, then you can bet when the ECM is operating off of the other tables, it won't be runnning the way you want it to.
WOT AFR vs RPM
Great thanks. I have tried making some changes but after I do and try to save it, I get a "Could not write to change log file". What does that mean and what do I have to do in order to save the changes I make. I'm having the same problem with changing my Mask and Checksum ID. What am I doing wrong or what do I need to do as well?
R.S.
R.S.
