Hi every body,
So I am a new user of the Tuner Pro, and I need to say that it's real pleasure to work with advanced soft.
I have any interest for all cosworth, and especialy for L8 IAW 048.
So just some question about it is some body can help me:
What is the knock table, I don't understand the value and when is used by the ECU
What is ECT and ACT "TRANSFERT"
I don't understand the function of map Failure
And all signification of ACT ECT RPM and MAP "something" ?
For finish the function of post crank enrichment
If any body have some information about this, thank you for your help
PS: And sorry for my english as you imagine, I m french.
IAW048-01 xdf questions
The 'Knock Table' is used when the ecu detects knock. The units and conversion are not known.tontonludo wrote:What is the knock table, I don't understand the value and when is used by the ECU
The 'ACT Transfer' and 'ECT Transfer' functions translate the sensor voltage to temperature values. The conversions are not known.tontonludo wrote:What is ECT and ACT "TRANSFER"
When the MAP sensor has failed the ecu uses the 'MAP Failure Table' instead of the MAP sensor reading.tontonludo wrote:I don't understand the function of map Failure
The 'something' values are just placements for items found but their use is not known.tontonludo wrote:And all signification of ACT ECT RPM and MAP "something" ?
Immediately after exiting crank some fuel enrichment is need otherwise the engine would stall. The 'Post Crank Enrichment Multiplier' table provides for this.tontonludo wrote:For finish the function of post crank enrichment
