I have just started using tuner pro RT on my 1992 camaro TPI and so far it has been great. It was super easy to set up and I was monitoring data with the dash in less than 10min.
Can someone let me know how to change to degrees F.
Also, another question... I determined that my manifold air temp is 142 F after the engine coolant is up to about 195 F. Does anyone know if 142 is too high? I have the MAP set up with the K/N air filter on the throttle body.
Mike[/url]
How to chage degrees C to F and a question about MAT?
F = C * 9/5 + 32
Cheers,
Dave
edit: I should say that '*' is multiply, '/' is divide ....ie; F = Cx9/5 + 32
Cheers,
Dave
Thanks..... Now how do I change it in the program..
Thanks. I know about the conversion equation, but was hoping there was a way to change it in the program. On the screenshots of the program, it shows the temperature in F, so I was thininking there must be a setting that I have set to C.
- Six_Shooter
