Scannerpro Build 630
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    TunerPro User Forum Forum Index -> ScannerPro Beta Discussion
sshook
PostPosted: Fri May 30, 2008 2:17 pm    Post subject: Scannerpro Build 630 Reply with quote
I tried to upgrade to the latest ScannerPro build 630. After the install and when I try to run ScannerPro I get this error:
C:\Program Files\ScannerPro\ScannerPro.exe
This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
I tried to reinstall and even tried to insatll on a PC that had never had ScannerPro and recieved the same error.
Thanks.
Back to top
dfddfd2
PostPosted: Fri May 30, 2008 3:16 pm    Post subject: Reply with quote
You probably need the vcredist_x86.exe Visual C++ run time librarys.
_________________
Back to top
View user's profile Send private message AIM Address
sshook
PostPosted: Sat May 31, 2008 4:17 am    Post subject: Reply with quote
That worked. Thanks.
Back to top
JP86SS
PostPosted: Fri Jun 20, 2008 3:50 pm    Post subject: Win98SE Reply with quote
Sad
Hopefully I just don't have the right versions of the "VCREDIST" libraries.
My Win98SE machine won't take. (My Vista desktop took everything fine its just hard to drive with that long cord trailing behind me Laughing
After installing the older version of the libraries I still get
"Program Expecting Newer Windows Version" or similar message.
The newer revision of the files did not want to load on win98SE.
Is this the end for my 98 machine?
I'll try some more but I'm not too confident it will work so if you know it won't you'll save me the trouble of trying.
John
Back to top
View user's profile Send private message Send e-mail Visit poster's website
PostPosted: Fri Jul 04, 2008 12:24 pm    Post subject: Reply with quote
Sorry, but the latest version only supports Win2000 SP4, XP, and Vista. This may change in the future, but it would take a lot of work. Sad
_________________
Back to top
Display posts from previous:
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    TunerPro User Forum Forum Index -> ScannerPro Beta Discussion All times are GMT - 9 Hours
Page 1 of 1
Jump to:
