Tuner Pro x2?
Tuner Pro x2?
Post by Six_Shooter »
Is there a way besides running two computers to have two instances of Tuner Pro open?
I just downloaded and tried to open Tuner Pro Free while having Tuner Pro RT open and it gave the same error as trying open a second instance of Tuner Pro RT.
Yes, I know there is the compare feature, but when I'm trying to compare bins that require diffefent XDFs, or trying to edit XDFs, it's easier to compare with two instances open.
Irocing
Post by Irocing »
Just wondering, would that happen if two computers would
be networked togeather :?: :?:
Thought of that idea while back also.
Have 2 computers and monitors side by side.
Didn't mean to hijack your thread but been trying to do the same
thing instead of the compare feature especially with the graphs.
Later :)
Irocing
Cudda bought a Z06 with whats in the car.
SAD, but fun!
TunerPro is a single instance application. That may change in the future.
Irocing
Post by Irocing »
Thanks Mangus,
Another option I wondered about, was being able to right click
on a graph or item and be able to print it. :?: :?:
Then be able to compare them side by side :)
Never was adept with spreadsheets.
Just a thought :wink:
Irocing :D
Irocing
SAD, but fun!
Mangus wrote:TunerPro is a single instance application. That may change in the future.
Ok, so it's not just me then. :lol:
At least you did include a bin compare feature, which is most comonly needed. :)
It's just guys like me that want to get into the code a little deeper or make sure everything is just how it should be that needs to run more than one instance. ;) :)
Six_Shooter wrote:It's just guys like me that want to get into the code a little deeper or make sure everything is just how it should be that needs to run more than one instance. ;) :)
I'm certainly one of those people, and I've never needed a second instance. ;-)
I'll consider it.
If there was a way to compare (and copy items of) different XDFs then I wouldn't need to use two instances of Tuner Pro. ;)
That's really about the only reason (currently) that I would like to have two instances running, maybe to compare ADS files, you know just about anything that can be edited. :lol:
Thanks for the consideration. :D
