Hello my name is Erik. I have been reading a bit about TunerPro and .bin files, .bin definitions, and the like.
I have a 1991 Chevy V3500 with a TBI Gen V 454. I would like to be able to data log my engine and transmission and eventually play around with tweaking the .bin.
I have heard from some people on other forums that there is not a .bin definition for the TBI 454 with the 4L80E transmission. I am not sure of the particular code mask or ECU number right now, but that is what I have heard.
I have read Mark Mansur's article on the Basics of creating an ECU file (or any definition file) from a hack. My question now is how do I start going about breaking down the code to get to a definition file? How have other hacks been created? This I haven't read about.
I am a Mechanical Engineer and also work with a bunch of EEs, so I have pretty good knowledge of electrons and if I don't know something I have pretty good resources. I have also played around with several aftermarket EFI systems, but never hacking OE stuff.
Anyways...can someone help this Noob with getting started? I know I need an ALDL cable, but as I said, I think I need a definition file before I can read anything off of my ECU.
Thanks in advance for any help!
Newbie here with a few questions about getting started
Need the numbers off your PCM. 454 with 4L80E in 1991 should be $85 mask and 138 ADX for engine or 177 ADX for trans.
Wish I knew how to answer the rest of your questions! Then I could do that to...
- Contact:
