Histograms Flag dependent
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Feature Suggestions
yoda69
PostPosted: Sat Mar 13, 2010 11:26 pm    Post subject: Histograms Flag dependent Reply with quote
Would be nice to be able to do histograms that are flag dependent.
ie.:
MAF Vs RPM Vs O2mv but only data that is in closed loop
MAP Vs RPM Vs Spark only in Idle mode.
MAP Vs RPM Vs Spark only with TCC Locked.
yoda69
PostPosted: Sun Mar 14, 2010 8:12 pm    Post subject: Reply with quote
Thanks!
_________________
yoda69
PostPosted: Tue Mar 16, 2010 6:59 pm    Post subject: Reply with quote
Mangus,
No problem, would be good if this feature would allow selection of multiple flags if possible, as sometimes it would be nice to filter the data based on a number of conditions.
Keep up the good work, as TunerPro just keeps getting better.
yoda69
dfddfd2
PostPosted: Fri Oct 22, 2010 4:25 pm    Post subject: Reply with quote
This feature is also discussed in these threads:
http://forum.tunerpro.net/viewtopic.php?t=2076
http://forum.tunerpro.net/viewtopic.php?t=1747
Dave
_________________
NismotronicSA Tuning Package/Powered by TunerCodeSA
Speed-Density Tuning for Nissans
View user's profile Send private message AIM Address
yoda69
PostPosted: Sat Oct 23, 2010 12:00 am    Post subject: Reply with quote
No, those threads are about filtering bad data.
The idea here was to be be able to select what data the histogram uses based on another condion or conditions.
ie. An rpm Vs load Vs O2 mv, but only when commanded AFR is 14.7.
This way any data that is from a power enrichment or lean cruise is ignored, the VE table could then be corrected based on the histogram.
yoda69
dfddfd2
PostPosted: Sat Oct 23, 2010 3:44 am    Post subject: Reply with quote
yoda69
It's the same thing. Filtering "bad" data or filtering "unwanted" data, it's the same result in the History tables. Also, if you read carefully, Mark points out that TP currently can't identify "bad" data in a received packet that is the correct length, only that a packet is incomplete or over-sized. In that case, you would need an "unwanted" filter to remove it.
Cheers,
Dave
_________________
yoda69
PostPosted: Sat Oct 23, 2010 11:30 am    Post subject: Reply with quote
No it's not.
I want to filter good data, based on a condition within that data.
I'm not sure if you have grasped the way GM ALDL data comes in.
Basically you can get up to around 64 bytes of data that come in in each packet that may cover engine speed, map, gear, coolant temp, TPS, knock, spark, and heaps of other parameters.
A histogram at present just looks at 3 bits of data (x, y and z), what I would like to be able to do is to have a histogram of x, y & z but only when A, B & C are true.
None of the data is bad, I'm only after a conditional Histogram.
yoda69
PostPosted: Sat Oct 23, 2010 11:39 am    Post subject: Reply with quote
You guys are saying the same thing.
_________________
dfddfd2
PostPosted: Sat Oct 23, 2010 12:30 pm    Post subject: Reply with quote
That's what I said...
_________________
Post new topic   Reply to topic    TunerPro User Forum Forum Index -> Feature Suggestions All times are GMT - 9 Hours
