Wanted ...sbc blower... Bin
i am running a 1995 355w 13.8 dished piston... tbi to mpfi conversion 8-44# injectors... roller cam is .510 gross lift ...195 trick flow aluminum heads...with the ati procharger... looking for a starter bin...any other info needed...obd1
- Six_Shooter
It would help if you also listed the ECM service number.
Look at $59, it requires the use of a '7749/'7730/'7727 and similar ECMs.
www.code59.org
www.code59.org
