Histogram
Locked
Cobra289
Histogram
Post by Cobra289 »
Hi,
First of all, I need to say that Mark has develop a wonderful tool.
I have made two histograms one for the BLM corresponding with the VE lower table and the other, BLM correspond with the VE Upper table.
When I edit the ADX and try to set the MIN to the highest RPM 6400 and the MAX to the lowest RPM, it keeps making the table the other way around.
This feature will be nice to have because the TunnerPro RT table is the other way around.
I can change the XDF for TP but that will destroy the standardization.
Would be possible to get this feature?
It will simplify a lot when you use the copy and paste of the total table.
I use excel to change my VE tables.
Regards,
Cobra289 (Carlos)
The Netherlands
"Improvement"￾ means that you recognize previous mistakes!
www.donostia.demon.nl
Locked
