405 Burble/Pops and Bangs
Hi all. Who can share the XDF file with the fuel restore address for 405 EBU. I will be very grateful
Re: 405 Burble/Pops and Bangs
Need to find curves with coolant temperature (d4). 405 dme have about 50 like this maps, which of them is a deceleration map, not many people know. Need to change the parameters and check each one. If don't have emulator, it is not easy to do.
I've read about this. Perhaps someone has already done this and there is a well-known map. Without an emulator it really won't be easy and time-consuming. There is another question: which variable is responsible for turning off the oxygen sensor?
I found only two maps in 405 DME, that can be, fuel restore.
- restore map (2).png (74.48 KiB) Viewed 36 times
