Is anybody kind enough to send me a bin ready to copy to my ecu, That would be so much appreciated.
I have searched all over the forum with no success.
I just want some power gains, and some flames here and there, I don't know if the ecu is capable of launch control / 2 step rev limiter, If it is, that would be awesome too.
I have an 94' e36 325i M50 Vanos with red label 413 ecu 623 chip. Things done to the car is a Gen2 57i K&N intake and a Full custom stainless steel Exhaust.
Here is my email: azizi.oussama.anouar@gmail.com
I would be so happy if anyone can send me a file.
btw I have a programer and a free eeprom.
Cheers.
Tuned file for stock M50B25TU with red label 413 dme
Re: Tuned file for stock M50B25TU with red label 413 dme
Hi
Do still tune 413 ecu ? Did you find your file ?
i have the same engine as you i support your request, would like to have the file too
Sendiri Pasword pleasee
Hi freinds.
Please note that you cant just use any file on your car even if ""stage1"" every engine is different. A file working great on another car might cause knock on your car . Start with an emulator some knowlage on how the systems work and a knock monitor. (Preferably with datalogging).
None of us were born knowing everything so try on your own and you will make a good file im sure.
Let me know if you need any help
Best regards.
Best regards.
e36_agd wrote: ↑Sat Apr 27, 2019 9:16 am Hello,
Cheers.
This is a .bin file I found, I used it as a base for my E36 M50tuB25.
It's a little better than the Original.
- BMW E36 325i 192HP 0261200413 357623.rar
- (30 KiB) Downloaded 204 times
