aldl cable
ThirtyTwo
aldl cable
Post by ThirtyTwo »
I made the two transistor type aldl cable and it works great using freescan, but I have to be in interact mode and hit "force data" once or twice. I can scan at 1ms delay which is the fastest setting.
I tried to use the cable with tunerpro rt and it wont connect and the cable test says it cant see a cable.
any ideas? Using sil's $df.xdf and $df.ads
Sil
Post by Sil »
did you manually "connect" it in tunerpro?
go to...
tools >> ALDL/Datalogging
then press "connect" ?
or the short cut would be to press ctrl+F4
