DME 403 SOFT 950 XDF
Evil
Post by Evil »
Here is my current XDF for DME 403:
https://www.catupload.com/download/dd96 ... a3567.html
Many things have been found thanks to the discussions we have on the 413/506 thread and the amazing work of Hairyscreech and Olafu (also Mykk who is very active on this thread)... So a HUGE thanks to them.
It is not 100% complete, some descriptors are still unknown (1C, C9, D1, D6), and many tables functions are still unknow, we can discuss here if some have infos for this DME . Anyway, ALL tables are listed.
I will update here all evolutions of this XDF.
aboutton
Post by aboutton »
Nice work bro 8)
HyperBoost Tuning
Tony Ouneissy
Lebanon
Mykk
Post by Mykk »
1C is vehicle speed. D6 is raw load, D5 is dampened load.
What Calc do you use to convert temperature header into actual degree?
Evil
Post by Evil »
For temperatures i use X*0.75 - 48. Thats the formula Ive seen on many threads here, dont know if its 100% accurate.
Are you sure for D6 To be raw load?? There is no D5 in 403, and I think raw and dampered load are D3 and D2 :wink:
Mykk
Post by Mykk »
Ohh, it's M3.1... unfortunately I dont know axis descriptors for M3.1
Hairyscreech
Post by Hairyscreech »
Evil wrote:For temperatures i use X*0.75 - 48. Thats the formula Ive seen on many threads here, dont know if its 100% accurate.
Sounds right, D2 and D3 are the equivalent to the D5 and D6 pairing in M3.3.1 everything I have seen points to a very evolutionary approach to these ECUs, even across processor variations and engine architecture changes much of the process and programming philosophy is retained.
Lambda1
Post by Lambda1 »
Link doesnt work :?
Did some know adresses for idle rpm tables?
Hairyscreech
PM evil, I am sure he can send you a copy and repost the link.
Evil
Post by Evil »
ikamac
Post by ikamac »
Evil wrote:https://transfernow.net/52btc4r29g7d
XDF re-uploaded :wink:
one more time :D
chaoukiel
Re: DME 403 SOFT 950 XDF
Post by chaoukiel »
Hi DIY tuners, :idea:
Can someone help me to get the XDf file for 403, I can't download them for the links posted on this discussion.
thanks in advance. :mrgreen:
aglv95
Post by aglv95 »
Hi, can someone share a good bosch 403 xdf please?
mahdi93
Post by mahdi93 »
this one is working for both 405 and 403
you should know how this ecu work before tuning dont just change numbers specialy rev limit donc just make it 7000 or 7200 it will be wrong
405-403 xdf.zip
(2.37 KiB) Downloaded 594 times
