Alfa M1.7 164LS V6 24V anyone have.xdf?
thedean
Post by thedean »
Hi Guys,
Does anybody have a .xdf definition file for a Alfa Romeo M1.7 0 261 203 287 ECU?
These ECU's came in the 164LS V6 24V's.
Chip number is a 1 267 357 623.
Michon
thedean
Post by thedean »
If anybody can help me with making one, i'd potentially be willing to pay. Just need a base definition so i can get started with tuning.
Thanks!
biela
Post by biela »
Hello
You can find some definitions here:
https://pcmhacking.net/forums/viewtopic ... 163e51e180
Hairyscreech
Post by Hairyscreech »
You can also start from the E30 M1.3 XDF as a lot of things will be very similar in the M1.7.
You will obviously have to find the correct corresponding maps and use the correct multiplications and offsets for the Alfa but the base code and way the ECU functions will be very similar.
If you take the time to understand how the maps work and why the E30 M1.3 XDF is set up the way it is you will be set for the M1.7
