Can't get it to start... the application that is
shippman
PostPosted: Thu Jun 01, 2017 5:58 pm    Post subject: Can't get it to start... the application that is Reply with quote
Just downloaded the very latest TunerPro RT app. First, it wouldn't start because it couldn't find the API-MS-WIN-CRT-STDIO-L1-1-0.dll on the computer. I downloaded the dll to the laptop. It now says it can't start because of error 0xc000007b.
Presently running Windows8.1.
Can you help?
Mielk1jd
PostPosted: Thu Aug 03, 2017 5:50 pm    Post subject: Reply with quote
I have also tried to install TunerPro onto my desktop, which is currently running Windows 8.1 and I received the same message.
"This program cant start because api-ms-win-crt_stdio-l1-1-0.dll is missing from your computer. Try reinstalling the program to fix this problem."
PostPosted: Fri Aug 04, 2017 2:36 am    Post subject: Reply with quote
The api-ms-win-crt_stdio-l1-1-0.dll appears to be part of the Visual C++ Redistributable for Visual Studio 2015. See here for the update:
https://support.microsoft.com/en-us/help/2999226/update-for-universal-c-runtime-in-windows
PostPosted: Fri Aug 04, 2017 8:59 am    Post subject: Reply with quote
Correct. Install this one, specifically:
https://www.microsoft.com/en-us/download/details.aspx?id=52685
You may also need to check for Windows updates after you install the above.
I'll fix this issue in the next release.
_________________
PostPosted: Sat Dec 02, 2017 1:57 pm    Post subject: Reply with quote
The latest version now requires the Visual Studio 2017 redist. The TunerPro installer should automatically install it, but some folks still seem to be seeing issues. You can manually download and install it from here:
https://go.microsoft.com/fwlink/?LinkId=746572
Then run Windows Update, reboot, and try launching TunerPro again.
_________________
Joshua-G
PostPosted: Fri Mar 23, 2018 5:54 pm    Post subject: Reply with quote
i am having this same issue as well and have done everything suggested and i still get the same error code. any suggestions? running a computer with windows vista. Any help is appreciated.
