DA: Not Connected?
supr91tt
PostPosted: Fri Sep 22, 2017 10:41 am    Post subject: DA: Not Connected? Reply with quote
I have retired my old laptop with TunerPro 5 installed and the old one connects and logs fine. The new laptop I connects as it finds the hardware and starts emulating but I am unable to connect the DA.
Both laptops are running Windows 7. Any suggestions?
PostPosted: Mon Sep 25, 2017 8:10 am    Post subject: Reply with quote
We'll need more info to be helpful.
What vehicle? What definitions?
What do you see when you test for valid cable? Do you have your COM port set to match the one your cable uses in preferences?
_________________
supr91tt
PostPosted: Mon Sep 25, 2017 3:01 pm    Post subject: Reply with quote
'87 Turbo Buick running speed density with LC-1 wide and and 3 bar map. I'm pretty sure the cable is working as Tuner Pro recognizes the Maft-Pro hardware. I'm just not sure what the "DA" portion is. That appears to be the ability to record, does that functionality require a license file? If so I'm unable to locate it on my old laptop to transfer. The old one works (super slow, on it's last breath) using the same xdf file and it appears to download the bin from Maft-Pro while emulating, which in my mind is also indicative the units are communicating?
PostPosted: Mon Sep 25, 2017 4:01 pm    Post subject: Reply with quote
No, it doesn't require a license. You'll need to set the interface type to "AutoProm/MAFTPro" on the data acquisition tab of preferences. Then you'll need to load the definition (ADS or ADX file) provided by the MAFTPro folks to enable logging.
-Mark
_________________
supr91tt
PostPosted: Mon Sep 25, 2017 4:16 pm    Post subject: Reply with quote
Thanks for the direction, I knew there had to be some configuration step I' d missed. I'll check it out in the AM!
