Filter for min/max values in History tables
I would like to see a feature added that sets the range of acceptable values for the history tables. This way, if you are looking at Injector pulse width, you can filter out when you are slowing down and the ECU fuel cut logic cuts the pulse width to zero.
Filters would be awesome!
Filters :)
As an expansion to this idea if it is considered for implementation.
Have the filter value selectable as one of three types.
a.) Numeric value (Integer or floating point)
b.) Data item value (ex: Speed > xx.xx, selectable from ADX list)
c.) Bit driven (ex: TCC = true, Selectable from ADX list)
Ability for any number of these values, stacked as go/no-go parameter for what goes into the data table display.
Jp
Jp
Update for filter
Howdy all,
Just wondering if there is any update to this?
I would like to add a TPS filter to history table for closed throttle & open throttle wideband afr error.
